glaxy1
Hello, I need some help.
Problem: my jet pump fluctuates between 15-35psi and will not build any pressure higher than that. There is a swooshing or surging sound that continually occurs.
Location: it pulls water from a lake to supply the house. Suction Lift is 40ft, distance from foot valve to pump is 90ft.
Equipment:
brand new 2 line version of the Franklin electric rm2 jet pump
Brand new, Cage/screen, venturi and foot valve
I blocked in the discharge of the pump.
I primed the pump by using a auxiliary plug -in pump plumbed into the top suction line.
I then circulated fluid through and bled the water through a tee on the discharge line for about an hour.
When the pump is off it'll hold the pressure solid so I don't think there are any leaks on the suction line.
The pump continues to swoosh and surge though there's still air in it.
Any advice?
Equipment:
Any advice?
