Several years ago I bought a dual flush kit to convert my standard toilet. For the longest time, it worked perfectly fine. However, in the last year the toilet has developed an intermittent problem whereby sometimes it will flush properly and other times it won't (usually "Number 2"). The problem seems to be getting progressively worse. I did notice that the water level in the tank was not coming up to the same level that it did when the original guts were installed. So, I've had to take the fill valve out twice now to adjust it higher such that the water level now reaches the previous water line. Still, the toilet's not flushing properly. Now, I don't have soft water and the water in my town is pretty hard. I'm wondering if calcium and lime have built up to the point that it's causing the fill valve to not work properly? The only other thing I can think to do is tweak the adjustment screw on the valve arm. Failing that, I don't know what else I can do or try to fix the issue without replacing the kit. Does anyone have any suggestions?
