htech
I'm new to the forum and installing bathtubs in general and was hoping to get some advice before I screw something up. I bought a Sterling tub and I'm about to install it directly on a concrete slab floor. The floor is off level by about 1/8". This is an above floor rough in tub so it sits on a plastic riser that lifts it up for drain clearance. My question is should I put mortar underneath the tub when installing it? My understanding of mortaring underneath a tub is so the tub sits in the mortar and it conforms to the bottom surface of the tub providing a sort of level "cradle" for it. Is that correct? If so I don't see how I can achieve that with this type tub. I contacted Sterling and they were less than helpful and just said it was my choice to use it or not. Can you guys tell me how you would install it? I just hate doing things the wrong way and regretting not asking someone before I did it. I've attached a couple of pics of the bottom of the tub.
Thanks!
Thanks!
