pasadena_commut
Installed a new Insinkerator disposal today. After it was rotated all the way "up the slope" on the mounting flange it is still possible to rotate the body of the disposal, which is good, because that is needed to line it up with the top of the J trap. But it is also bad, since there seems to be nothing but friction and force on the outlet tube to keep it from moving. Is there some trick to lock it so that it cannot rotate once it is in the desired position? (The instructions which came with it don't mention anything.)
The previous disposal, from the same company, was making some unpleasant noises but kept working. What finally caused it to be swapped out was that the end of the outlet, the part going into the T for the other sink, cracked and started leaking. It was thin chromed brass, like the rest of the pipes. When it was all taken apart the tip of the lateral from the other sink was also cracked at its tip where it went into the T. While those pipes were old, I think what may have happened is that the slight twist when the disposal turned on and off flexed the tips of those two pipes back and forth until they cracked. Admittedly not a huge problem since it took 25 years to fail, but better no motion at all.
In other news, the wire inside the armored cable from the wall to the disposal, was found to be shedding its insulation on the disposal end. I could pull it apart with my fingers. It is possible that this wiring is as old as the house, built in 1957. Anyway, Home Depot didn't have anything like that on the cut to order spools (only needed 3 feet of it), but they did have this:
https://www.homedepot.com/p/Southwi...-CU-Lighting-Flexible-Whip-55082415/203387031
It worked really well. It was also kind of expensive - win some, lose some. Cut it in half (roughly) and the fitting on one end snapped perfectly into the metal plate for the electrical box. There was no specific grounding screw inside the box but there was an unused mounting screw, so that was used for the green wire. Almost certainly not code, but heaven only knows how this box is grounded, almost nothing in the house is. The disposal says to install a strain relief for the cable, which it does not supply nor does it suggest any part numbers. The cable in the drawing doesn't even look armored, more like lamp cord. Hoping to get lucky, the fitting from the unused end of the cable was transferred over, but it was too big for the hole in the disposal. For once I had guessed that this might be a problem and got one of these ahead of time:
https://www.homedepot.com/p/Halex-3...e-Metal-Conduit-FMC-Connector-91100/100212971
which screwed into the supplied hole in the disposal and nicely clamped the metal armor on the cable. It might not be quite the right choice, but it is certainly better than just leaving the cable dangling out of the hole suspended by the wires.
