There used to be a clear plastic handle on the stem sticking out from the valve, it's broken off. You will need to use a pair of pliers or a channel locks to turn the stem. You can also change the guts of the valve (turn main water off to the house first) and then you know for sure everything is gonna work. Most times those handles break when the valve gets tough to turn off.
