pasadena_commut
Redoing the drain under our double kitchen sink. Bought a kit with all the parts (supposedly) to hook up the drains and the disposal, but it only works if the disposal moves to the other side. That's OK with me since the disposal is being replaced too. Unfortunately, after removing all the pipe from the side of the sink with the strainer what is left has no obvious means of removal. There is no nut on the bottom, no nut on the top, no thumbscrews or set screws. The picture is from the bottom. The top shows the other side of the bottom of the strainer and then just smooth metal. (Edit: well, there are 5 slightly raised vertical regions distributed around the inside of the cylindrical cup above the strainer, but I certainly don't have any tool that would fit that.) I thought about putting a big screwdriver in the rectangular hole and turning it, but it is probably stuck on pretty well, since it has been in place for at least 28 years, and possibly as long as 65 years. No way to get a grip on the partial hemisphere part, for instance with a strap wrench, it would be like trying to grab the top 1/4 of an orange.
My best guess is that I'm supposed to bang on one of the 6 raised flanges around the perimeter, for instance with a block of wood and a hammer, to cause it to unscrew. Hard to believe though that it was installed like that.
Is there a better way?
Thanks.
Thanks.
