That’s a Delta 1700.
The brass ring is suppose to unscrew counterclockwise.
They have to be carefully cut off quite often. You have to be careful or you’ll ruin the entire valve.
I usually don’t cut through the ring but rather deeply score it then insert a flat screwdriver and twist. This breaks the ring so it will unscrew.
