GoshenPlumber
Goshen Plumber
I called Danze and they said that the handle assembly can be unscrewed from the top. Mine is too tight. Using a wrench to loosen it - even with cardboard or similar material under the wrench - will mar the soft metal body of the handle. Is my only choice to remove the mounting hardware assembly underneath the sink by unscrewing the two screws, replace the cartridge, then re-install the assembly? Am I missing something? (See drawing)
