MichaelSen
- Joined
- Jul 30, 2023
- Messages
- 7
- Reaction score
- 0
All 5 laterals of the drain field in my septic system is completely clogged. I've verified that water is getting pumped into the pipes but it's not making it all the way through the pipes when the end sweeps are open.
I had the lines jetted but it didn't solve the problem. I suspect that the company that did it wasn't very thorough and stopped at the point that it hit a blockage. Clearly the blockages were too tough for the hydro-jet to break through
Is there an alternative, stronger tool for breaking up those clogs - like an auger with a metal bit that's used to break through roots in sewer lines? I'm trying to avoid having to dig out the pipes and replace them
