Recently had a hot water heater replaced, which exacerbated a problem I've always had with my hot water lines: calcium/lime deposits. Thin egg-shell-like, pastel-green colored, flakes in the pipes.
Usually not a problem. I clean out the lines at the clogged faucet and it's good for several months. But, now I'm having trouble at the kitchen sink and I'm hoping I could get some help. (I'm a complete amateur when it comes to plumbing, so please forgive the lack of proper terminology.)
Relevant facts:
Why is there a check-valve in this quick-connect thing? What purpose does it serve? More importantly, is there some way to back-flush that valve? I tried to connect a cheap plastic tube directly from Point A to Point D and turn on the hot water, and it was a disaster with water spraying everywhere. Now that I drew up the diagram, I see the error in my ways -- there would be nowhere for the hot water to go unless I turn off the cold water and then disassemble the ball-valve at Point C (which I didn't do). Even then, if this actually is a check valve, would water even travel backwards through that valve?
Unfortunately, I cannot get rid of the quick-connect thing at Point D. It looks like it is integrated into the rigid tube that comes out of the ball-valve.
Any help would be greatly appreciated.
Edit: I found a picture of the quick-connect thing, directly from a Moen schematic:
Relevant facts:
- Kitchen faucet is a basic Moen single-handle pull-down faucet from Home Depot (Link to HD here: Moen "Indi" Faucet).
- Hot water pressure at the faucet was low, so I did my normal routine.
- Turn off hot water valve, disconnect at Point A (see diagram), and pick out flakes from the spigot and tube.
- Put faucet handle in neutral and turn on, which back-flushes cold water out of the hot water tubing.
- Reconnect, and do the same thing on the cold water side for good measure.
- This resolved the hot water pressure, but then I noticed that both lines had lower than normal pressure coming out of the sprayer.
- So I cleaned out the sprayer at Point B and I disassembled the ball-valve at Point C and flushed out all pathways.
- But, the pressure was still low on both lines, so, I decided to check the main output line that has the black weight attached to it.
- What I realized is that the line (with the black weight) is connected to the rigid tube coming out of the ball-valve with some kind of quick connect junction (Point D).
- When I disconnected that quick-connect and looked up into the quick-connect junction, I saw that it had some kind of check-valve inside it. A white, plastic, mechanical structure that completely blocks the view up the tube. Upon closer inspection, I could see tiny fragments of the calcium deposit (like sand) trapped around the inner perimeter of the valve.
- I have a suspicion this is where my blockage is.
