What about PVC?ABS is the easiest to work with. Cast iron would need a chop saw with grinding/cutting wheel or a snap chain cutter.
good to know. One of the main reasons you can't use it here is when the vents are going out of roof, the sun would break down the ABS.Hawaii’s UPC code requires ABS. PVC can only be used for lawn sprinklers.
I see. Informative.Goo
repairs are ok.Your not aloud to use ABS at all in VA.?????
