How’s the best way to go about clearing an urinal toilet?
do you mean a urinal...there is no 'urinal toilet'. Ultimately, if the drain is occluded, you need to determine and evaluate all conditions.
Some people say if it's not draining don't bother trying to snake it,just pull it and go from there.
We use urinal augers or a small drain cleaning mach guaranteed way is to pull it and snake it, general makes 2 auger versions, the on you want has a bulb end on it , It also extends about 3',so you can pasd the ty in the wall, key is to usr mild pressure while spinning the auger,its kind of a feel when you do it enough, the cable is a small diameter and can ki k easily if you force it
Got you,thanks.
