They do make hand expanders. Which are a pain to use, but work. About $150-$200 with the diesThat's pex tubing I think it's unipor requires a
Special battery operated gun but I think you could cut it a few inches after the 90 coming out of the tank and unwind it from there,your still stuck using pex, to reconnect
WHY IS IT ILLEGAL?This is an illegal way to pipe a water heater.
You can take a wrench and unscrew it where i have it circled.
The are metal flex connections that you can use in place of this pipe. The fittings have been mechanically expanded and settled onto the fittings.
WHY IS IT ILLEGAL?
again, that was not the answer I was looking for. Thank you and have a lovely day.Because some codes say it is.
Only on gas here.Most codes want 18” of metal before transitioning to plastic.
Only on gas here.
