The way my house was designed, was a total DIY. I have two hot water heaters that work in tandem on opposite ends of the house. So both water heaters are sending water to the same shower. I read about the solution is a pump that will, on a timer, put the water in the pipes back into the water heater. Since I have two water heaters though, would both need it? Do these things actually work well?
