Hi! I have a question on the existing builder installed pressure regulator on my house supply line. The Watts Regulator Model N45B M1 which I believe is supposed to only have NPT fittings which attach to the unions at both ends. It looks to me like the plumber-builder took the outlet union off and rigged some sort of PVC / PEX fitting to the end of the PVC pipe and cemented it into the outlet of the regulator.
This doesn't look right to me and has major potential for a leak... correct?
A Ha... I found out that the regulator has INTERNAL 1" NPT threads inside the housing also... they used a 1" Pex to 1" Brass NPT adaptor to tie it together.
