I have an outdoor shower I need to winterize. It has a Moen diverter(mixer?) valve with hot and cold water going to it. There is also a valve a couple feet down from the diverter that seems to drain the diverter. I have shot-off the inside hot and cold water valves (the cold water line also runs to the outdoor hose bib). When I remove the vent cap from the inside hot water shut-off valve and apply air pressure to the line, the line pressurizes but does not flow no matter how I position the outside diverter valve or diverter drain valve (if that's what that valve is).
I can gravity drain most of the water, but the pex has droops so I want to blow all water out of the lines to the outside shower. What am I doing wrong?
Should be an easy DIY job, no?
Thanks
Thanks
