If it doesn't work exactly as advertised it is not just a return, it is a warranty. While our written warranty is only for one year, we have never held anyone to a time if there was something wrong with our valve caused by a manufacturing defect. I would warranty a 10 year old Cycle Stop Valve if it was a manufacturing defect. But even just a year written warranty should be plenty of time to decide if it works and you like it or not. Not worried about getting it back once you see how it works. Lol!
Being that a "community" relies on this water system makes it even more important to have a CSV. Your 120 gallon size pressure tank holds about 30 gallons of water. The fact that the tank is going bad is another clue the pump is cycling a lot, and a CSV will be extremely helpful. Even though you have a whole community on this water system, with a CSV added I wouldn't waste money on any larger than a 20 gallon size pressure tank if that one is being replaced. Everything in the pump system will last longer with a CSV, and the whole community will be talking about the much improved water pressure.
