Help with toilet valve
Discussion in 'General Plumbing Help' started by Habs_fan, May 25, 2018.
  1. May 25, 2018 #1
    Habs_fan
    Habs_fan
    Habs_fan
    May 25, 2018
    I am replacing the old toilet in my condo with a new one. Condo was built in ’01. The previous toilet valve shutoff was soddered on to the copper pipe but wasn’t totally shutting off the water so need a new shut-off valve installed.
    1st attempt:
    Cut the soddered shutoff with my angle grinder & installed a Sharkbite. Turn water back on to condo but had a drip…drip..drip coming from where the copper met the insert hole of the Sharkbite. Thought maybe it wasn’t in far enough so tried everything I could to push it further & same issue.
    2nd attempt
    Cut off the Shark using angle grinder & tried a second Shark…same issue.
    3rd attempt
    Cut off Shark using actual pipe cutter – cut was very clean and even. Used plumber sandpaper to clean off the cut and ensure no burrs, etc. This time I installed a multi-turn valve like the following: https://www.homedepot.com/p/BrassCr...et-Multi-Turn-Angle-Valve-OCR19X-C1/202047058
    After tightening I am finding its not very tight around the copper pipe and I can basically pull the entire valve off. Is the issue that I am not tightening tight enough? Is it possible the copper pipe is smaller than ½”?
    I am literally loosing sleep over this thing
  2. May 25, 2018 #2
    johnjh2o
    johnjh2o
    johnjh2o
    Senior Member Professional
    Jul 21, 2011
    3,223
    740
    Melbourne, Florida
    Tighten it more using two wrenches. One to hold back on the valve the other to tighten the nut.
  3. May 26, 2018 #3
    mind.of.hutch
    mind.of.hutch
    mind.of.hutch
    May 14, 2018
    11
    Use two large vise grips and tighten the compression nuts as tight as you can. The only thing I would of done differently is get a quarter turn shut off valve. Multi turn valves can leak a lot easier. Also shark bites are nice but can leak.
  4. May 26, 2018 #4
    RenewDave
    RenewDave
    RenewDave
    Feb 18, 2018
    260
    52
    Call a plumber. He/she will do the job correctly and warranty the work. Shark bites are not a good s9lution.
  5. May 26, 2018 #5
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    828
    187
    Mansfield,, Ohio
    Make sure the brass ferrule is under the compression nut. If you are tightening the nut and the valve comes off
    then the ferrule is not in there.
    havasu likes this.
Share This Page
