I need some assistance. I have, apparently, a hot water leak under a slab!
I will try to provide as much information as I have. Have a water softener (on first floor) and that is how I heard the leak, hissing and noticed that it was flowing at 0.6 to 0.7 GPM. After checking all toilets, sinks and faucets , hot water tanks (on second floor) and pop off valves on the tanks. I can not find a leak. So I turned off the hot water circulator, still hissing sound so I turned off the hot water outlet and the hissing stopped. Now what. I can hear the hissing sound at each sink, the hot water tank and the softener.
I have a multi level house and so far no water coming from the ceiling. There are three baths on a split level 2 and 1 both on slabs. How can I trace the leak under the slab? Can it be done without removing all of the furniture and stuff from each room?
So I turned off the hot water tank outlet and no hissing or water running through the softener. So I will keep off until I need the hot water. Which is a guess at least a small blessing that I can stop the leak temporarily.
Thank you so much for the help. I am desperate!
