So, did you do away with the shower? This looks a little different than the earlier plans.
So, I assume the green dot under the washer is the floor drain? If so, I would run the 45 off the main that catches the washer straight to the floor drain, and then add a vent for it up the wall next to the door. I assume the sink at the top of the drawing has a drain to the main pretty much mirroring the others on the drawing. The vent for that sink can go up that wall beside the window and either tie into the main vent stack, which I'm not sure where it is now, or through the roof as a separate vent. An AAV could also be used, but I personally hate them unless there is no way to conveniently use an atmospheric vent.
