SWarnock84
Hi All, I apologize for the length. I couldn't find a previous thread that matched my situation exactly...
I have a multi-tank aerobic system. I went to put chlorine tabs in my aerobic system the other day...and realized that I hadn't seen the grey water sprinklers come on for several days which was unusual. Went over to the control box and flipped to "test" but nothing happened. At that point I opened the control box and notice that the "test" breaker had tripped to the off position.
I flipped it back on - and now I have a solid red light at the control box, but no alarm tone - even when flipping to the "test" position.
I called the closest septic company (I'm pretty remote so there's only one option) and he said my pump is likely bad and it will be about $1300 for him to replace it. So I decided to dig a bit further...
Opened up the last tank, disconnected the coupling, and lifted the pump/float assembly out. It's a Sta-Rite 1/2 HP effluent pump with 3 float switches. Here's what happens when i actuate the floats:
-lower float appears to be doing nothing - regardless of whether the timer in the box is set to normal, on demand, or with the timer engaged
-middle float turns the motor on and off regardless of other float positions - yay...so the pump is good right?!
-upper float appears to be doing nothing - no alarm tone or change in the solid red light when
Does this sound like bad floats? Shouldn't I be getting an alarm tone when the top float is turned upside down?
