Hello, I have a bathtub with 2 handle setup, American Standard valve stems(#1520) and the cold water stem is leaking water out the front. It is a brand new stem I've just installed because the old one was leaking.
But after install, the new one is still leaking. I bought the replacement stem new, with all new washers and o-ring, so those should be good.
What would my next step be in addressing this leak? Something to do with the seat? I've tried looking up info, but hard to find anything other than replacing washer/o-ring on stem, and particularly hard since there's no info out there about these kinds of stems.
There is also a drip out of the faucet, which I assumed is being caused by the same problem.
I don't know if it helps or matters, but the cold water stem leaks even when I turn on only the hot water handle, and the cold is still shut off.
Also, the drip out of the faucet slows down to almost nothing after I take a very hot, long shower (via shower head adapter, this is just a bathtub setup)
Thanks
Thanks
