Did you have that tee connector before the disposal was installed.
Tighten this lock ring before your disposal falls off the flange.
Yea, it drained fineDid it drain good when it was just a double sink only. If not, then you will have to cut out that 90 degree elbow that the trap is going into and put a tee in its place and an AAV on top of the tee as high as possible to where you could replace it. If you do this then get a disposal drain kit and install it instead of that center tee. And for what they cost get a new 11/2" p-trap. If it still drains slow after all this then the drain needs snaked out.
