ruwiredup
Hi everyone,
My 1992 home has the original Watts pressure reducing valve and it is staring to fail. Pressure dropping off rapidly when you first turn on any fixtures. I have been turning the pressure up little by little to keep things flowing but I am out of adjustment, the screw is all the way in now.
I would like to rebuild it rather than replace it if possible to avoid having to cut it out and sweat in a new one as it is in a tight area in the wall next to my water heater.
Unfortunately, my local pluming supply house Ferguson can not come up with a part number or availability of a rebuild kit based off of the Id Tag (Pictured).
Unfortunately, the white paint on the edges of the tag will not come off without taking the blue/white of the tag with it.
I have not yet cut open the wall to see what size pipe it is but was hoping the id tag might decode to which rebuild kit, if any, is available.
Worst case, I will just replace the whole unit but I figured I would share the Id tag and see if anyone had any input.
If there is any other info I can provide, please let me know.
