Guys, I have a bathroom sink handle that is leaking from base of the handle whenever I turn on the water. Please see image attachments.
I think the sink is original and had a heck of a time removing just the handle. I'm stumped on the next problem though. Now that I have the handle off, I can't seem to remove the escutcheon and hence cannot remove the stem to get to O-ring/washers. The escutcheon will not budge. It almost seems fused to the stem itself (not sure if you can tell from the pictures). There doesn't seem to be any seam between the escutcheon and the stem assembly. When I twist the escutcheon by hand the whole assembly seems to rotate, escutcheon + stem. Btw, is the nut that you see on the picture the packing nut to remove the stem or is it part of the stem itself. The space between the shell of the escutcheon and the said nut is only a few millimeters, not really big enough to get any kind of wrench in there.
Any help is appreciated!
