I purchased a house last year with a clawfoot tub. It doesn't have a drain stopper and I don't understand what I am looking at. I'm obviously missing a part to the drain.
Do I just need a rubber plug? Is this a piece to a toe tap stopper?
Additionally... As you can see the whole assembly looks a little rough. The middle knob to switch the flow to the faucet does not work. I can only use this as a shower. Also, the knobs for the hot and cold fall off
I'm guessing I'll be better off replacing the entire thing? They are pretty expensive from what I've seen - around $200 - $300. Any recommendations? i don't care for the hand attachment but it needs a faucet and pipe to the shower head.
Thanks in advance!
-Adam
Thanks in advance!
-Adam
