abacus822
I just purchased this:
KOHLER Canada: K-R13492-4: Kelston® Rite-Temp® pressure-balancing bath and shower faucet trim:
Kohler bath and shower fixture set for updating old bathtub/shower fixtures. I was able to remove the tub spout very easy, it just screwed off. I found a plastic pipe (threaded end) that extended out from the wall and it got very thick as it got closer to the wall (it looked like there was a copper pipe underneath it). I removed this "covering" to find a copper coupling?? underneath. I am really not sure what this piece is and all of the websites I go to for images of "fixtures" do not show me the same shape as the attached image. It appears "dumbell" shaped with a threaded end (which the plastic covering pipe screwed onto) that hooks to the wall pipe and the other end has an O-Ring with a 3/4" opening (this end has no threading inside or out). Please Help!!
I would like to be able to install a .25" nipple coming out of the wall 5" like the instructions indicate but I am not sure how to do it in this case.
Any help on this matter is greatly appreciated.
