So I have two things, this is in a commercial building suit, about 25 years old:
1)I want to change out this sink/vanity to a new one. But I'm not sure if the pipe in the walls are PVC or cast iron. I have a feeling it's cast iron because of all the other pipping in the building are cast iron (had leaks in my unit and that what the pipes were made out of). So my question is, how do I undo this metal connection to fit a PVC connector to it? Can metal and PVC pipes mix? I'm not sure how the pipe/connection looks when coming out of the wall.
2) I want to change out a faucet, but one of the handles of the water shut offs were broken.
I don't believe there's an external water shut off valve for the suite. What is this round thing?
I understand it's to get access to the pipes in the wall. But once it's off, it looks like this.
Is it used to shut off the water to the pipes running to the faucet? And how would I even turn this thing with such a slot?
