Thank you. Very helpful!If you are putting in a new sink, you should install an AAV. It looks like you will need to cut the drain line below the existing sanitee that the existing P-trap arm goes. You need to check your local codes to see if this is allowed in your location. You should cap or plug the other line below the floor where it goes into the sewer line. See my sketch, and I apologize for its messiness.
You may want to 45 off the new sanitee, or come off the Sanitee at a 1/4" to the foot slope, to move the AAV to the side of the sink to get it higher than the bottom of the sink. Some jurisdictions require the AAV be above the flood level of the fixture it is venting. In any case, the higher the better and provide ready access to it.
