All 3 my toilets and the tanks all of the sudden have gray water! There are two upstairs and one downstairs. The sinks are running clear. Any idea what this is or why it happened? Thanks!
My guess is it’s mildew.The water in my toilet tank also looks dark and there are a lot of black specs in it. After I clean the toilet with a brush, it gets a dark coating from the water line on down in just a few days. My sinks don't have that problem. I'd like to find the root cause and have it tackled.
It has lots of black specs and dark build up on the insides. I've used the tank cleaner I got from Amazon and it helps for a couple of days. I'll check into the mildew possibility.Same question as before, what does an inspection of the inside of the tank reveal?
What tank cleaner did you get from Amazon?
It did work, but the black coating on the bottom of the tank came back. I checked the flapper, but it doesn't seem to be the problem. It was slimy, but not black on my fingers. The tank in the other bathroom also has dark matter in the bottom of it, but not as bad. It coats the bottom of the tanks. I can brush it off and flush it down. Still investigating./*
Instant Power Toilet Tank Cleaner – Bathroom Toilet Cleaning Powder, Removes Rust and Other Minerals, No Scrubbing, 16 Oz
OK, and did it work? How does the water in the tank look before and after? If you lift the flapper with your hand, do you get black (disintegrated rubber) on your fingers? It _feels_ like your flapper is disintegrating from here, given the information you've provided.
I recently had a septic line (big pipe in the basement) cleared of roots which were causing a backup into the tub. I would turn on the sink faucet and water would come up in the tub. Since I had the roto-rooter type of machine clear the roots, the toilet doesn't have that dark film on the porcelain (water level). It's only been a few days, so I'll keep checking to see if it comes back.
