Jim Jensen
OK, this is an old house that my Mom bought, she is 82..... house built in 1960.... at some point after that, a neighbor helped owner drill a shallow well, right behind house..... 4" thick concrete block pump house, that had one wall about to fall OVER, when she purchased, in 2018.... I demolished pump house, and re-did the piping.... recently, the PVC 1" threaded fitting into the pump, blew out....( I had accidentally left the pump RUNNING, with all outlets shut OFF, I guess that caused it ???
Anyway, I am trying to connect NEW, 1" sched 40 PVC, into the old piping, but it is NOT sched 40, not sure what it is...... Diameter is 1.38"..... measured with my calipers.... they had a PVC union, already there, that connected that existing manifold pipe...(it is split off into 6 zones, each with a manual cheapie PVC valve).....to SCHED 40 PVC...... the old pipe is really thin, about 1/2 the wall thickness of the sched 40 1" pvc pipe.....but it is TOO WIDE diameter for a 1" sched 40 union, to fit on it....
I am sure someone out there (prolly OLDER guys,..) will know EXACTLY what this stuff is, and if there is still a PVC union, to connect the two.... that is all I am after, for now..... Eventually, I will junk all those manual valves, and put in electric valves and a timer..... manually running six zones for 20 or 30 min each is a MAJOR PITA, in Florida !!!! ha ha THANKS in advance, for any help / advice.
Jim in Jacksonville, FL
