Hello everyone,
I'm trying to figure out how to increase the temperature on a shower. I'm in a recently-built house and right now it only goes up to lukewarm.
After opening things up I can see the temperature control right there - all I should need to do is turn it counterclockwise a bit.
It looks like if I could get that brass "cap" on the stem off then I'd be able to remove the first plastic disc and then then take off the temperature control, turn it, and put it back on. But I can't figure out how to get the cap off. The cap is able to move slightly up and down on the stem which makes me think it isn't screwed on. Turning the cap just turns on the water since it's the thing that the handle grips onto. There is a screw that goes into the hole in the center of it and connects it to the stem (removed in the picture). That screw was definitely one thing keeping it on, but even with the screw removed I can't pull it off. I've tried as much force as I dare.
The outside of this faucet looks like one of these but what I'm seeing inside doesn't look like anything in their assembly instructions, so I'm at a loss.
I'd really appreciate some ideas.
