Didn't want to step on the OP toes for the other thread going on but had (what is probably a stupid) question...
(also) looking into a whole house generator and wondering why you "would not" run the largest line possible? Example: my meter (250 CFH) is fed by 3/4" (no pressure rating on the (pre-meter) reducer) and the house is fed by 1" (have not measured the pressure there yet).
Question is, is there any reason not to tee off the 1" line and run 1" to the generator (approx 35' run)?
Question 2ish - one of the generators I'm looking at (24kw) has the following 1/2 and full load requirements:
Fuel Consumption @ 1/2 Load - NG cu. ft/hr 203
Fuel Consumption @ Full Load - NG cu. ft/hr 306
Based on the meter spec above is there a possibility we'd need to upgrade the meter? There are 30 other homes in the development with similar generators and I haven't seen any the had their meters upgraded
