I have a pretty old house built in 1930s... with two garages...with drive in sloped pretty much as well as all the backyard leading to garage is sloped too.. so when it rains heavily(as it was last week in a few min my garage was overflowing with 2-5 " of water gurgling up from my garage drain pit..... now I have a problem what should I use to control the flow of heavy rain outside which collects at the bottom of slope leading to drain outside the garage and then into the pit in garage to further into city sewage...As I understand the volume that big was too much for the sewage(4") and it collected into my garage... as soon as the rain stopped, the drain emptied with noise instantly.. so I understand the pipe to city sewage is OK.. I bought sump pump... but as I emptied the pit of water and tried the pump in it's physical location, I discovered that the level of water in the pit that should be contained there to prevent the smell from sewage and the level of the floating switch of pump to start and stop were too different
The pit is W: 14". Lenght:26", Depth 26"
The water level to the pipes is 16 "
Should I be looking for another type of pumps?;; Like not submerged type, but regular , dry type with automatic water level sensor?
Looking for help.... Thnx for reading.
