pasadena_commut
When connecting galvanized pipe to copper pipe through brass how much brass is "enough" to ward off problems with galvanic corrosion?
Is the length of a ball valve sufficient?
In many posts on the web people say to use 6" of brass, but none of them cite their source or explain why 6" is the magic number and not 10", 5", or even 1". Dielectric unions are another way to go about this, and in those the ends of the two dissimilar pipes appear to be at most 1" apart.
Also, when this transition is from the house to the service line, and it is acting as the house ground, I assume that if brass is used nothing else needs to be done to maintain the ground since all of those metals conduct. If a dielectric union is employed presumably two brass clamps on either side with a copper wire connecting them is needed to keep a functioning ground. Does a jumper like that reintroduce problems with galvanic corrosion?
