According to the manual this valve is set at 15lbs. It will go up to 50lbs. To do this you have to loosen the screw on the red
knob and then you can turn it to the higher pressure. Just make sure the zone is open to bleed out. You probably already
know this but if it isn't you will blow the relief valve and have water everywhere. Don't turn the fast fill on and then forget
about it. Won't tell you how I know this. LOL..........
Not quite sure how the fast fill can be automatic. We only use the fast fill feature to bleed out the zones. You have to
do this on a new system or one that you worked on. This is the one that we always used.View attachment 22353
