frozen line between house and tank
Discussion in 'Septic Tanks' started by nation99, Oct 4, 2019.
  1. Oct 4, 2019 #1
    nation99
    nation99
    nation99
    Oct 4, 2019
    menominee, mi
    A few years ago were gone for a month during winter and the line from our house to the septic tank froze. Since then I have dug up that line and insulated around it. We haven't had that problem again, but we haven't had the same conditions (very cold and little snow) while we've been away.
    We plan to be gone longer this winter and I'm concerned about having a freezing problem again. I'm considering connecting a water supply line from either the cold water (likely about room ambient temperature) or the hot water supply to the drain near the exit from the house and have it controlled by a solenoid valve and a timer so it would run water for a period of time several times a day. Make sense?? Or could there be a problem having too much clean water flowing through the system?
    Any thoughts would be appreciated.
    Thanks, Dave
  2. Oct 4, 2019 #2
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,645
    2,368
    hot water freezes faster than cold water..i dunno why, physics thing
    if you are not home, and no water is being used, then the pipe should not have any water inside of it to freeze
    the pipe is sloped, gravity drains
    i am confused as to your problem.
    but..if you think you need to heat your unused drain pipe
    buy some heat trace wire, fish it down the pipe,
    you are good to go...do not forget to remove the wire after vacation, so you can use it again next year
    https://www.supplyhouse.com/Easy-He...ping&msclkid=07d9191b77391093a0bc448c32365890
  3. Oct 4, 2019 #3
    johnjh2o
    johnjh2o
    johnjh2o
    Senior Member Professional Lifetime Supporter
    Jul 21, 2011
    3,263
    745
    Melbourne, Florida
    The heat from the septic tank should keep the line from freezing. I have seen this happen but in most cases, they had the septic tank pumped in the winter.
  4. Oct 9, 2019 #4
    FishScreener
    FishScreener
    FishScreener
    Aug 23, 2018
    298
    85
    83467
    The rich folk over at Sun Valley have a foam insulator with a heat trace wire that is on the bottom of the pipe.
    Us poorer folk put sides and a cap of 4-inch poly-iso foam installation. Six inches below the invert, a foot outside the haunch, six inches above the crown.
Share This Page
