Hi all,
thanks in advance for the help. Background info: have had numerous floods in our basement- always had to call in the plumber and run the snake to unclog it. Finally changed the main line to a new pvc. Thought all our problems were solved. Fast forward less than a year, and started getting flooded again. This time, we would have water entering even without running any water in the house. always started with a gurgling in basement bathroom and slow draining when that toilet was flushed. Within days, the water would start to come into the basement through the caps of the main line. Interestingly, our neighbors a few houses down have the exact same problem with the exact same warning signs. They have not changed their main line to pvc. We now think it’s a town problem, but they won’t seem to help. They ran a camera through the towns line, and it looks like there’s a load of tree roots, a crack in the side, and a belly right after the opening to our mainline. I assume this because there is a ton of sitting water in that area. And this was filmed after they jetted, so this was the cleanest it will ever be… my thought is that the towns line is clogging due to roots, then getting stuck in the belly, then backing up into our line and eventually into our basement. Is this possible? If so, how do I prove it? Any and all help
Is appreciated. Thanks
Ps- happy to post pictures if you think it will help.
