I have a straight run (about 8 feet) of thin-walked solid-wall drainage pipe that I jammed with a shovel. I don't have enough room too fix it with PVC couplers ( meaning, I can't bend the pipe enough to perform the fix), but I could use a fernco flexible coupler. Except, the only 3" fernco coupler I can find is meant for sch 40 PVC with an outer diameter of 3.5", and this pipe is 3.25. I found a no hub coupler which fits, but, it's not rated for underground use.
Is there such a thing as a fernco coupler that fits drainage pipe? As an alternative, I found a hard coupler which fits drainage pipe to sch 40, but this stupid pipe rests on my foundation, so I'm concerned about the diameter of the couplers involved, and lifting this pipe too much when fitting these together and causing a crack elsewhere.
A slightly smaller fernco would be ideal. Do they exist for the thinner-walled drain pipe diameters?
Thanks,
Chuck
Thanks,
Chuck
