My problem has reached a new stage and my subject line no longer suits the problem. Care if I start a new conversation with a more accurate subject? the original conversation is here.
I've now managed to remove the valve; there's a picture of it below. But I wasn't able to fix the leak; in fact, the leak is worse than ever, after disassembling the valve and replacing two washers. So why is it still leaking? Probably because when I removed the valve I removed some string ("packing"?) that was packed behind the packing nut (not shown in the image; it's threaded on the outside and screws into the main valve body). I assumed it was some sort of kludge, a temporary fix that had been in use for years. It wasn't keeping the valve from leaking, but it was helping some, apparently, because now, without the thread, it's leaking worse.
So what's the proper way to fix this?
