Fittings That Glue INSIDE PVC Pipe
Discussion in 'Plumbing Products' started by Jeff Handy, Nov 30, 2019.
  1. Nov 30, 2019 #1
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    680
    95
    Chicago suburbs
    Howdy friends,
    I stumbled onto something today that I did not know existed.
    Pros probably know this, but there are some special pvc fittings that install by being glued INSIDE the end of pvc pipes.
    Not glued onto the outside, as usual.
    These would be ideal when there is no access to glue a normal fitting onto a pipe stub.
    Like a pipe stub cut off flush to the fitting it was glued into.
    This situation would normally require chiseling out the pipe from the fitting socket.
    Or using a special “socket saver” bit to bore it out.
    Or for trying to tie into a drain, but the stub has been cut flush to a tile or hard surface, with no clearance around it to be able to slip a fitting over it.
    Many other tough situations could be solved with these adapters.
    Yes, they reduce the pipe inside diameter and flow, but in a pinch they could be just what is needed.
    https://www.pvcfittingsonline.com/resource-center/pipe-extenders-and-inside-connectors/
    Jim Jensen likes this.
  2. Dec 1, 2019 #2
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,124
    358
    North Reading, Mass.
    I see no reason why those wouldn't be legal for pressure lines.
    Of course gravity lines would be a different story.
    What's wrong with this example?
    Hint: what size pipe would be going in the socket end?
    MASTRPLUMB likes this.
  3. Dec 1, 2019 #3
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    680
    95
    Chicago suburbs
    In that situation as pictured, you would not be attaching anything “inside” the socket.
    It is not a socket.
    It is an extension of the pipe.
    You will be gluing a fitting or a coupling onto the outside.
    Imagine that clear pipe was cut off flush at a solid wall, for some stupid reason.
    And you had to attach to it.
    Even a drain could be attached to it.
    Yes, there would be a small uphill restriction.
    But most drains will develop that on their own with time, and they continue to work well enough.
    I have seen the tee where a trap arm enters it about half blocked at the bottom.
    Still drains ok.
    This would be only a small bump in the road.
    About 1/8 inch rise.
    Not ideal, but could be a savior in a tough scenario.
    Pbly totally against code having the flow not constant downhill, but real life sometimes has to win.
    I have seen barbed fittings used on flexible drain lines, and they create the same situation.
    Meanwhile, I just posted this because I have never seen these fittings mentioned yet on here.
    Not interested in starting any bickering war about codes.
  4. Dec 1, 2019 #4
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    2,124
    358
    Sorry I missed the simple fact that it was just extending the OD of the pipe.
    Yes, I think it is quite interesting and could very well be useful to many. Except the true professionals, of course.
    Agree, something you can't discuss relative to code, only its potential usefulness when the occasion arises.
    Good post.
  5. Dec 1, 2019 #5
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    680
    95
    Chicago suburbs
    BTW, when I mentioned bickering war, I meant the folks just laying in the weeds, who are bound to jump on this for code reasons.
  6. Dec 1, 2019 #6
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,368
    1,329
    Southern California,
    Hey now, I am in charge of pulling weeds around here. I obviously need to use some Round-Up? :buriedinsnow:
    Jim Jensen, MASTRPLUMB and Jeff Handy like this.
Share This Page
