Hi, first post. Thanks for welcoming me.
My sister's 2 boy's are home from college and her shower/bath is leaking.
The shower leaks about 6 ounces in 15 minutes into the cavity where the access panel is. No leak when the water is running into the tub. The plumber quoted her $1500 to fix the leak but he can't get to if for at least a few months. She just wants the leak to stop for now.
I opened up the access panel in the adjacent closet and can see the leak.
With the shower running the water is dripping but when I place my hand on the what looks like a diverter valve assembly (integrated into the tub spout) everything is dry. The water is only dripping from down lower where the surround meets the old cast iron tub. I thought for sure it was a leaky panel or bad caulk joint. But I taped plastic shower curtains all around the walls of the shower stall and ran the shower only to find it leaking exactly the same as before.
Where could the leak be coming from if not from inside the stall? Could the spout/diverter valve leak from somewhere closer to the surround panel?
Note: up at eye level (top of shower stall) the shower head has a threaded chrome stub that leads out of the wall to the showerhead.
