Faulty well oump
CTDIYER
May 21, 2015
7
Hello. I recently purchased a piece of property in VT. I'm starting up a well that's been dormant for about 3 1/2 years due to the house burning down. I hooked it up to a generator to see if it functioned. It took a bit but I started to get some flow of water. It would flow for about 3-4 seconds and then stop for about 30 seconds. It would gen flow for about 3-4 seconds again. Also at the first the water was clear then it turned muddy. Any thoughts in this? Does the pump need to be replaced?
Valveman
Pump Controls Tech
Professional
Lifetime Supporter
Jan 6, 2010
616
117
,Lubbock, Texas
Is this a two wire pump or three wires with a control box?
CTDIYER
May 21, 2015
7
It's a 3 wire. 220v. It's not hooked up to anything right now because the house burned down. I hooked the wires from the pump directly to the generators 220 outlet
Valveman
Pump Controls Tech
Professional
Lifetime Supporter
Jan 6, 2010
616
117
,Lubbock, Texas
A three wire pump needs a capacitor start box. The two wire from the generator go to the control box, then three wires from the control box to the motor. Won't start without one.
