Faulty actuator or valve?
deanomix
Nov 18, 2020
Chichester
Hi all,
New member (and novice!) but have a temperamental problem with my Drayton MA1 3-way actuator. It’s recently started sticking on the hot water and I need to lift the actuator off the valve for it to switch over to CH. Once it switches back to HW I put it back onto the valve and it works for a while (switches freely between HW and CH) but then eventually the same problem occurs and I have to run the manual process again.
Is the actuator faulty (which I think I could change myself) or does the valve need replacing? Any advice is greatly appreciated.
You are in England, most members on here are from North America, but maybe someone will recognize that setup.
