Faucet removal/replacement help
Gabkicks
Oct 25, 2011
Hi, I'm unsure of how to remove my faucet. there's no manual, and the manual for the new faucet shows a different part than the one seen in this video. :eek:
[ame=http://www.zshare.net/video/95170399e0652373/]zSHARE - MVI_3535.AVI - Free File Hosting Service | Audio and Video Sharing | Image Uploading | Web storage[/ame]
the video would have been better with music...
anyway, behind those two 3/8's copper supply tubes, you should find a nut... it'll be roughly be a 3/8's socket size and be about an inch tall... it threads onto a rod that protrudes through that horseshoe shaped washer...
As FlushMasta says, carefully bend those copper lines forward (up in the picture) and you will see the nut which will need to be removed, with a socket and an extension. Once the nut is removed, the faucet will pull out the top.
