Just curious if you would add strapping to this installation? I'm not a plumber. Just trying to learn. I see it done like this a lot. Really don't know if it's right or wrong.
run a piece of steel strap iron from the 90 where it connects to the tank to a ceiling joist.
Will the pipe break ? Probably notbut maybe if conditions get right....
The problem is when the bladder fails in that tank it will fill with water. That makes it heavy. It fills with a little water sometimes but when it fails it fills up totally.
A more likely situation would be the water heater nipple rusts away and it breaks at the lower portion of the tee. It could happen.....
Your plumbing codes most likely requires it to be supported by something other than the pipe.
But initially it’s very strong. I’ve hoisted water heaters into attics by 3/4” pipe thread connections.
