Metal structures are grounded and they need to be bonded, which is a bit different- it maintains an equipotential state in the structure and boats, houses, etc are bonded, too. Even ground wires connected to the stakes outside were connected to the cold water pipe as close to the electrical service panel until plastic pipe entered the picture. Communications cabling from phone, internet and cable/satellite TV providers is also supposed to be connected to the fuse/breaker panel or a cold water pipe as close as possible to their entrance into the building and is required by a couple of NEC articles.
An anode shouldn't be conducting a lot of current- if it does, it will erode very quickly, the building should be considered dangerous and metal pipes will erode faster. It can also indicate electrical wiring problems.
WRT safety, imagine a plumbing problem where the water supply pipes have been used for grounding the electrical service and the main drain pipe has been replaced with PVC or ABS between the lowest floor and the foundation, so the water is the conductor and the PVC acts as an insulator. Until someone is in the shower while the water is draining and they grab the metal pipe with the shower head. The water completes the ground, but the problem is that the person becomes the load.
