My bathroom has two sinks, each with its own p-trap. The pipes then disappear behind a wall before converging at a common drain. When I run the water for a little while on either one, water begins to fill the other sink. They will then drain very slowly.
I tried a hand snake, but it keeps routing to the other sink. I also tried a sink plunger without success. Is there something else I can try myself?
If not, what does this type of clog typically cost to fix? I've asked for two preliminary quotes so far, and they are both over $350.
Thanks in advance for any advice.
