Drum Trap with vent.
DMD1960
May 8, 2019
13
64151
Usual story. Circa 1960 house with drum traps for tubs. Have found articles and videos on replacement with p-trap but unable to find anything relating to when there is a third connection going to a vent.
Also, this appears to be lead. Does that complicate things ?
Thank you.
frodo
Just call me Macgyver
Professional
Supporting Member
Sep 28, 2014
8,137
2,581
The vent will transition to a galvanized pipe in the wall
you will need to cut the sheet rock behind the tub wall and remove the lead pipe
tie onto the galvanized pipe
cut the wall in the room behind the tub.
DMD1960
May 8, 2019
13
64151
That looks like the setup. How do I tie the vent pipe back into the P-trap after I take the drum out ?
frodo
Professional
Supporting Member
Sep 28, 2014
8,137
2,581
remove the drum trap and the lead pipe
back to what ever it ties into, that is not pictured
tie onto that with a fernco proflex band
and repipe it with pvc
post picture where led ties into the cast iron
DMD1960
May 8, 2019
13
64151
drum4.jpeg drum5.jpeg drum6.jpeg drum7.jpeg drum8.jpeg Can't see it very well but, it looks like the vent pipe goes up about a foot before joining a different pipe.
The drain runs to a bigger lead looking pipe, that I assume is under the toilet, which attaches to an , I assume, cast iron main outlet. Is all of the dark grey lead ?
One problem is that the tub wall backs to another bathroom with a full vanity in the way .
wood4d
Apr 1, 2014
193
39
south jersey
I am not commenting on advice but whomever did that job looks like he earned his money. One of the finest lead jobs I have ever seen
Diehard
Aug 19, 2017
2,640
469
North Reading, Mass.
I find it hard to believe they were still installing lead drum traps in new homes in 1960.
DMD1960
May 8, 2019
13
64151
I'm understanding that all of the lead needs to be removed and replaced with PVC ? I can't just remove the trap itself and replace with a P-trap ?
DMD1960
May 8, 2019
13
64151
There isn't some kind of PVC to lead coupler ? The pipe leading into the long drain pipe at a Y is also coming from a second tub with a drum trap.
DMD1960
May 8, 2019
13
64151
Hmm. Much bigger project then I anticipated. It looks like the pipe directly under the toilet would have to be replaced also.
voletl
Dec 17, 2014
800
249
New York
Lead bends used for toilets are different there are ways that you can reuse them or attach a coupling on to them
DMD1960
May 8, 2019
13
64151
After pondering this I think I'll call a pro on this one :) Thank you for your advice.
' Man's got to know his limitations'. ' Dirty' Harry Callahan.
