I found effluent reaching the surface of my back yard. It's reaching the surface at a specific point, then running downhill.
A professional septic company diagnosed a failure of the drain field. They determined I need a new drain field and a new septic tank. My septic tank is functioning normally, but there is some sort of code issue that requires a new tank if I replace the drain field.
Their estimate is 10K if the drain field can remain in my back yard, 14k if it needs to be relocated uphill to my front yard. I have a stream at the back of my property, about 100 yards from the current drain field, down a steep slope.
I'm not confident in their diagnosis, so I'm here seeking opinions.
The effluent reaching the surface is at a point that's uphill of most of the drain field. The amount coming out appears to be less than what's going into the tank. They said that its is near end of the drain field, but records indicate the drain field terminates several yards away from where the effluent appears.
My house has 4 bedrooms. My septic tank is 1500 gal according to records filed with the county in '74. Septic company thought it was 1000 gal.
I suspect my septic system has been in the current condition for many months. I've smelled the effluent on occasion, but only recently discovered where it reaches the surface. The smell increases when i have guests in town so it's related to use.
What do you think is going on?
